We didn't board the panels,but there was a 3mm gap left.Weber applications man called to site and gave us a talk through on how to complete the job(rendering wise).He said to caulk the joints with the basecoat and mesh with 100mm on all joints prior to fully basecoating.He said to do this 1st thing in the morning before fully basecoating the whole wall.He said "im a brim and braces man myself and I would caulk and mesh all joints to give more strength"."For the sake of an hour in the morning do this,go have yere tea,return and then fully basecoat the wall.He also stated in his "chat" not to apply basecoat over dry basecoat.When we started filling joints the basecoat filler was dry within 30minutes(no messing or exaggeration,30 minutes).He said that by filling the joints that the gear should remain moist for an hour at least.I rang the weber man and put across to him that the joints had dried rapidly within 30 minutes and what to do now.His reply was that to go up now and "key up" the joints with a scratcher and before fully basecoating the whole wall sprinkle the already filled joints with water to kill the suction.He also said that if I found that the boards were "pulling" quickly that to hose down the boards with water prior to basecoating??????Does all this sound right.At our site meeing with builder and meself never once did he mention to dampen any part of any wall or say anything about if this or that starts to dry/pull fast.He said that this gear is lovely to use bladeebladeebla...!He also said that after rulling off your panels to leave to set/take up for about 2 hours before sponging down.I was sponging the 1st section after 40 minutes straight after we finished rulling off.We kept an eye on the panel every 5 to 10 minutes or so as we were putting on the second pass and each time we checked it we could feel it pulling/going off more and more.Now remember these are only handy panels consisting of 7 boards.
