Hope that base coat is absolutely spot onUsing a texture gun and an external higher output air compressor.
Doing one myself with my Ritmo L, Swing gun and Meko compressor in about two weeks. Come for a butchers if you want we need a hand.
135m2 wall divided in two by an expansion bead. Job at Holmesfield between Sheffield and Chesterfield. Hoping for a Saturday but not the 2 June.
Product is Parex dpr fine sand. 1mm grain.
That Dpr is fewkin pricey.Using a texture gun and an external higher output air compressor.
Buckets go further spraying it on thoughThat Dpr is fewkin pricey.
A swing gun is my next purchase
I'm not a Hollywood plasterer like some of you boys on here.Buckets go further spraying it on though
I’m more BollywoodI'm not a Hollywood plasterer like some of you boys on here.
I’m joking mate. No doubt it’s bang on.The render is Parmurex and is bang flat and smooth. I barred back, poly float finish.
The 1mm grain is a worry. One pieceing is 12 m long.
Good thing is it faces North but the slightest breeze will skin it. Need at least 1 bloke keeping a wet edge until the gun comes down a level.
I need a cold dry windless morning.
Are you not just spraying and leaving it? No worries with scarring then.
Wow! A right fussy fecker thenNot that lucky. This customer has seen it rubbed up and knows what he wants. He wants to be there seeing it done.
Probably teaches engineeringWow! A right fussy fecker then
