tiger striping
daz1968
i have heard tiger striping mentioned a few times but what do they look like and how do you avoid them cheers
its a term use for stripes /lines that appear in your finish coat when you second coat on a to wet first coat and apply to much pressure on the trowel when troweling the wall or ceiling up,cause most of the second coat has been removed but troweling to early the first coat drys darker and grins through finished job making it look like strips on a tiger ,looks pretty naff and shows through the finished paintwork .
i find it happens a lot when you scratch on pulling up from the bottom and down from the top and then laying down the same way.
i scratch on up and down and then apply the 2nd coat across (opposite direction) then change every time i trowel. seem to show up any hollows so you can fill them while its still workable. give it a crossing on the last trowel and don't throw water on it.
Mac I think your really missing a trick by not giving the walls a diagonal trowel to pick out all the hollows.
bodplasterer said:
Lets just all blame bg that seems to be the right thing at the moment ;D
You cant blame them anymore its not fair its just not fair, also richard had an apology and a £200 voucher of BG so it cant be BG :)
Look it can't be BG's fault cause I have their answer here look:
https://www.plasterersforum.co.uk/plasterers-forum/general-discussions-on-plastering/i-phoned-british-gypsum!/
