Aslong as you have keyed the render it will be fine to tileok lads I'm working on this bathroom I'm so keen to get my wall spot on wher it been tiled I now some tilers they can be T***s .I have floated the walls whith sand cement over the years I have skimmed them up. Is ther any nead to skim them before tiling ?and if so y
Nook lads I'm working on this bathroom I'm so keen to get my wall spot on wher it been tiled I now some tilers they can be T***s .I have floated the walls whith sand cement over the years I have skimmed them up. Is ther any nead to skim them before tiling ?and if so y
Y skim then m8??Skim
What weight and sise of tiles got to do if u skim wall or not lolDepends on the size/weight of the tiles with the skim coat....
BS states 20gk m2, your bog standard ceramics 6-7mm thick would be fine...What weight and sise of tiles got to do if u skim wall or not lol
So bigger tiles u have got to skim For some reasonBS states 20gk m2, your bog standard ceramics 6-7mm thick would be fine...
Sand & cement is brill for tiling - just give it a good devil-up...jobs a goodinok lads I'm working on this bathroom I'm so keen to get my wall spot on wher it been tiled I now some tilers they can be T***s .I have floated the walls whith sand cement over the years I have skimmed them up. Is ther any nead to skim them before tiling ?and if so y
It's better to have a float finish rather than being keyed for tiling , just thought I'd throw that in thereAslong as you have keyed the render it will be fine to tile
b*ll***sIt's better to have a float finish rather than being keyed for tiling , just thought I'd throw that in there![]()
Or thinking outside the box, you could try Solvite All Purpose Adhesive...it's the only one you need.ok lads I'm working on this bathroom I'm so keen to get my wall spot on wher it been tiled I now some tilers they can be T***s .I have floated the walls whith sand cement over the years I have skimmed them up. Is ther any nead to skim them before tiling ?and if so y
I've done a lot of this mate. Get the s/c dead flat and plumb, float it nice, then gently devil it and after a while pass a trowel over to knock back any s/c crumbs. A nice tight finish with a light key is what your after. Obviously this is only my opinion.ok lads I'm working on this bathroom I'm so keen to get my wall spot on wher it been tiled I now some tilers they can be T***s .I have floated the walls whith sand cement over the years I have skimmed them up. Is ther any nead to skim them before tiling ?and if so y
Do u do rendering then thought u were a car lite basherIt's better to have a float finish rather than being keyed for tiling , just thought I'd throw that in there![]()
Class description...you could teach?I've done a lot of this mate. Get the s/c dead flat and plumb, float it nice, then gently devil it and after a while pass a trowel over to knock back any s/c crumbs. A nice tight finish with a light key is what your after. Obviously this is only my opinion.
Thanks mate....only took four hours of research to come up with that,.......I might write a book!Class description...you could teach?
I think your find it's not b*ll***s mr knowall knows fu ck allb*ll***s![]()
Explain then Mr makeshitupI think your find it's not b*ll***s mr knowall knows fu ck all![]()
I can'tExplain then Mr makeshitup![]()
A proper tiler would know what a mechanical key wasI can't,but I know that the tilers would prefer a rubbed up finish , must admit I do devil float it myself because it's less agg , but if you asked a proper tiler he would say a rubbed up finish, that's the right way .
why does tiling adhesive need a mechanical key? Have you ever tried getting that sh it off ?A proper tiler would know what a mechanical key was![]()
Everything works best with a mechanical key it's a lot stronger than a man made key I'm sure you know that. The tiles you and I have tried to take off sand and cement were put on a different way to how tiles are now, ie soaked and put wet on wet.W
why does tiling adhesive need a mechanical key? Have you ever tried getting that sh it off ?![]()
But a key is betterAqua boards don't have a key on them either, nor does skim or floor screeds. Not really necessary just a good primer
I think @Natwasere has answered the question
Thank you and good night
