Do not add it to water.What is the best thing to use to beat the setting time on skim plaster
100 percent success rateDo not add it to water.
Did not thing of that100 percent success rate
They look real
They are ......... and barely aliveThey look real
This give you more time mateBoard adesive
What we do when it’s this hot is when filling water buckets with hose pipe is spray each other down,head to toe just leave shorts on , run straight in room , mix up and shout let’s have it
Yeah but only do it on first coatThis give you more time mate
Best answer of 2018 so far pmslDo not add it to water.
Hate window wallsCouple of teaspoons of cream of tartar or only put on as much as you can manage, which means you might get the reveals on by middle of the week
does the heat do something to the render. couldnt get a mix right today. it was like it had too much mortar mix in it
