Tyrolean stucco question
GARZX9R
Hi, I've got a section needs matching to existing property which is a fine finish tyrolean, I haven't got the gear to spray on so I was thinking would putting stucco on finished off with a roller give a similar finish, not an expert on external rendering etc so would appreciate your views, cheers
Hire a Tyrolese gun or buy one
So if I use a tyrolene gun it'll obviously go on, on thin passes, the existing is approximately 15mm thick, what would you's recommend as a Base coat to apply the tyrolene to.
If your using coloured Tyrolean paint a wash over it just by mixing the powder with water, it gives it the colour and you don’t have to put so much on
