plasjack Active Member Jul 2, 2015 #1 Right Don't wanna sound thick boys But can you paint straight over varnish with gloss paint? And anyone got any tips on a real good finish? Cheers J
zolco Private Member Jul 2, 2015 #2 I would buff it up with some 180 grit, then spray or roll the gloss. Spray is nicer end result with a good airless
TonyM Private Member Jul 2, 2015 #3 If it's a stain varnish, use aluminium primer after a good sanding down. Gloss paint tends to chip off otherwise.
TonyM Private Member Jul 2, 2015 #6 Actually Zinsser Bin primer is what you want. It's easier to use and covers more easily.
Jgreenplastering Private Member Jul 2, 2015 #7 Bit of rend aid then some mono on top of chosen colour. [emoji106]
