I haven't but pretty sure I've heard it mentioned on here, whilst your waiting why not check out fundraiser, goes to a great cause and some cracking tools to be won
Versa Rendaboard is a modern practical construction material of outstanding performance. It is non-toxic, contains no hazardous volatiles and is asbestos and formaldehyde free. Versa Rendaboard is available in 9mm & 12mm thickness, 2400mm x 1200mm. And also other sizes available.
Just check with render boards when using with certain render manufacturers,
Some are approved with certain manufacturers, some aren't, if it ever failed for what ever reason, they'd just walk away.
