Victas
S a plastering
Hi does anyone know the coverage for the victas render thickness plus meterage I know the top coat is 3-6mm at 2m thanks
Cheers for that mate but meant the top coat skim to trowel up
They changed the spec now its goinonsome sort of supalux
Fire resistent board with a skim on it Cheers
Oh right, maybe it's changed then bud the stuff I used you couldn't trowel it up at all could only flatten it in..
They recommend 25mm for the base coat ,which only covers 0.5 metres so it gets expensive. But you can put a scratch coat on with normal s&c at 3.5 to 1 at 10-12mm followed by the vitcas at 10mm.
