Only when the plaster is firm enough should you do youre first wet trowel.Just a touch of water,i use one of them bottles to put a fine mist of water to the plaster and you know when its firm enough cos the plaster on first wet trowel should fill in any imperfections.I then leave a bit do a final wet trowel then last dry trowel.
