whats the best way to do a wall that curves at the top in to the celling and is curved all the way around the top of the wall .its like the wall is part of the celling . that make sence?
the curve continues on to the celliong all four walls continue in to the celling should i just do it in sections? what if only one of the walls need to be skimmed do you gradually blend it in to the celling. im just enquiring as i saw one of these walls the other day and thought how it was done. glad its friday cant wait to get me amereto tonight
I think i know wat your on about there mate something like you would see on an attic conversion you bound out the curves first then skim the whole lot in one go .
If the ceilings already curved you will need to hit it in one if you cant manage it try and get some one to give you a hand not a good idea to break it up as that means patching which is never good.
the scrim can fall off taking all the bonding with it , then land on the only uncovered part of the staircase which is made from oak, then youre flask brakes.......then you trip over youre scaffold and spill youre piss bucket all over youre leg ...........had a mare today ;D
