If using wet sand do you just dilute the waterproofer less...say half a bucket of water with 250ml of waterproofer per 25kg of cement instead of a full bucket?
If the mix isn't wet enough is it ok to whack some clean water in?..(the waterproofer already in the mix) I assume it is.
