alright lads, wondering which waterproofer products would be best to use that is available local prior to pebble dashing. builders yards local to me are huws grey, jewsons, wickes, b&q, travis perkins, wirrel builders, thanks for any advise ???
so cementone is the stuff then and it controls the suction in the scratch coat good nearly forgot do i need waterproofer and plasterciser interg or just waterproofer only?
Freeflow and Everbuild 3in1 are both waterproffer and plasticiser, Everbuild is also a retarder, I've used the Everbuild for about 4 years now and never had any problems.
U need both m8...the cementone is a mix of both check bottle should say waterproofer and plasticiser. I did a mix once without plasticiser...never again!
Don't take it for granted that whatever product you use will definitely waterproof your scratch coat, a lot will depend on what type of blocks or bricks you're working on.
