weber ocr as a base coat
S a plastering
could this be used as above say 5mm then pral m ontop just to cut down on mixing when handballing on cant really see that weber do a basecoat and rendaid is quite expensive
yep weve done it before aswell, as long as you give the top coat of pral m a decent pass.
Hello so o could use Weber ocr as it bit cheaper for s base and my mesh then spray on Weber pral m? As I need assistance on iseing Weber stuff Aswell as k rend
I've only ever used k rend so would like to know is it similar does it go off quicker is the affect better thanks guys
Ellis
All the best with rendering project mate:D
Looked cold outside today, checked my thermostat when I nipped to my van for a coffee and fag break highest it got was -1c :confused:
Lovely and warm in the room I skimmed though :bailando:
