Weber OCR quick fix
S a plastering
got about 4m2 to do an will have too hit it in one day so won't get chance to Rendaid it's just over brickwork which is pretty good nick will sbr slurry be ok first with Weber just for the suction issues really thoughts please
it's this mate the block work and some brickwork around the door
Weber OCR quick fix
not sure what you mean with the ratio bit mate do you mean an sbr slurry
No I mean mix sbr with your first pass of ocr at a ratio of 4:1 water/ sbr. A slurry prior is extra work that's not needed, this is the beauty of bagged render it's time / labour saving.
never done that before what's it like to spread with sbr in mate ok
That's up to you to decide- do you want it wetter, stiffer, timing etc. But let's say you use 4L per bag , that makes 3 bags and 3 handfuls of OCR
