Hi folks,
Looking for some advice ref build-up for external render for my new build. I know NOTHING about plastering (or virtually nothing).
So this is about 250m2 block wall external plaster job and my spec is approx. 20mm total build up of (1) sand/cement scratch coat and (2) rubbed-up sand/cement coat. My final coat I'm considering getting a mono specialist to do from an approved weber list, to do a single finish coat of an off-white weber tf plast or tf sil (1.5mm).
So the questions for you experts if you'd be so kind:
(a) weber tf plast or the more expensive silicon version (about double the price)?
(b) for minimising cracking I have cut, for the convenience of the plasterers, nylon reinforcement mesh for the corners of all windows/doors, extending about 1 ft into the wall in each direction. Does this get pushed into the scratch coat or should I do a rendaid coat, cover the lintels with this and embed the reinforcing mesh into the rend aid?
(c) Is there something I should be careful about ref this mesh - i.e. not push it too deep so that it is not 'fixed' to the blockwork underneath?
(d) Are the sections of mesh I have prepared ("L" shapes for the window corners and another "L" with a notch for around the window edge, around window cill and below the cill) big enough to reduce the cracking. I've got loads of left over mesh from a previous refurb (it's k-rend bought for under a k-lime internal plastering job) so should I be more generous with it?
Thanks in advance!
Thanks in advance!
