asmith2005
Does anybody have an advice on rubbing up Weber Pral M using a plastic float instead of a scratch float? Can this be done to get a smoother finish?
Thanks,
Andrew
Thanks,
Andrew
you cannot float finish any monocouche renders. this brings the fats to the surface making the surface the strongest part which in turn will cause failure.
what about ocr thats a monocouche render by definition of its translation :flapper:
