weber
RemovedUser
Im starting some rendering this week on a extension with some oldish (white) weber PRAL M.
The problem is its over celcon blocks one side will be 2 coat s/c and the front as you look from the bottom of the garden will be mono.
the builder wants to use steel beads as that's what he got on site and don't want to pay out for more.
anyway soo that means it will have a 10mm finish after its scraped.
im planning on putting a full mesh bed in the first pass of mono.
what about some sort of primer over the celcons first.
i tend to just wet the blocks with a hose if im S/C rendering
iv got PVA cement SBR water proofer plastering sand on site
sbr over the blocks?
sbr slurry over the blocks?
s/c scratch coat with a dash of water proofer in the mix ?
we the blocks with a hose ?
or just go over the blocks with no primer or wetting?
If the gears out of date it'll fall off, you want to use rend aid as a prerend and use proper beads stainless will look gash
yep i know i wanted to use 15mm upvc beads and rendaid but the builder is a propper knob and if got money still in the job or id walk away will it no go over a s/c scratch with a dash of water proofer just asking
gud luck
hose the crap out it then slurry it,i used rendaid few weeks ago its gud stuff
then hand applied webber chalk thought it was not great to handle but i was just using trowel after ruling to rub up before scraping
