what is a QUOIN CUTTER
Cutting quoins?
Sorry
I think a quoin is a type of stone so I imagine its a stone cutter of some sort.
Anyone know?
if you glued two old 2p pieces together and cut them into a fifty pence piece you could get fags out of a machine :D .................................fook knows good question though i see em for sale on ebay has it got anything to do with stones on the edge of buildings ?
Quoins are the corner stones of brick or stone walls. Quoins may be structural, or may be decorative. Architects and builders use quoins to give the impression of strength and firmness to the outline of a building. Rough-finished or rusticated masonry is also frequently used for foundation layers of buildings to give the same impression. Quoinage can be carried out in stone on a stone building, with stone on a predominantly brick building, or by laying brick masonry to give the appearance of blocks at the corner. If structural, quoins are usually part of load bearing walls; if decorative, they may be made of a variety of materials including brick, stone and wood. The most common form of decorative use for a quoins uses an alternative pattern of rectangles that wrap around the wall, mimicking the pattern of stone blocks or brick as they would wrap around a corner and thus join the two walls. In Georgian architecture, wooden quoins were most often part of an overall theme to imply stone, and thus permanence.
There I knew I knew it!!!!!!!
