I like to use the correct ratio for the substrate I'm working on at the time.
Note to self: Stop answering stupid questions.
Concrete block can be done four to one with lime or plasticiser or a waterproofer depending on requirements , I generally keep five to one with lime as 5/1/1 as my strongest mix, I use fibres now too, two handfuls in the mix, also might use mesh embedded in scratch.Just rendering block work just wonders how u all do it as most I know are different
I'm a 3:1 topped 4:1:1 lime guy mixing holm sand opc and waterproofer
Fibres in the top coat can appear in the render finish , I avoid using them in the top coat now but some with more experience of them do, you could try with half the amount but the coconut look scares me a bit, not as bad as that of course but a few fibres sticking out here and there, yes four to one for backing on concrete block and five to one as floating coating, I personally like five one one with lime for floating.Cool do u put fibres in top coat and are you putting5.1 on a 4.1 bk coat john
I have not got used to fibres in top coat yet, do you use small fibres or the normal 20 mm ones,
Andy, when you put the fibers in the top coat do they not show through when its rubbed up.?
Errrr.....ok thanks:RpS_unsure:Yeah they look fecking terrible but I still keep using them :RpS_confused:
Yes ,I need to get some more types, just got travis Perkins fibres and the are 20mm as standard, sarcasm aside as if how do you judge how many to put ina mixer to avoid them been on the finish coat protruding out ?
Does anyone burn off the showing fibres in the top coat?
I've thought about it before! :RpS_laugh:
I have also heard a whisper that Speedskim are in discussion with Gillette for a solution :RpS_thumbup:
Surely they're not going to try to solve a problem that doesn't exist are they?
