SpankySouthport
Which type of render mesh should i use for movement cracks internally? i know probably most will do but might as well get your opinion?
Cheers
Cheers
Why so thick ,60 mm is a bit over the topThat was my thought cheaper the better, do you reckon just in the scratch or? Gonna be about 3 coats then skimmed, 60 odd mm thick! :rolleyes)
Need to bring it back out to the original level![]()
Why not dab boards??? It'll take an age to dry out at that thickness
Spanky, is it the same job you posted re the cracked cornice ?
If they want it put back solid, what material were you thinking of using?
Spanky, you know when it's the little things that bother you, well here's one..........It's S & fkn C
that's a C!!!!!!!!!!!
Spanky are you with a polish bird?
no al spanky uses sand and semen..........................t
Yeah it's my favourite additive, people think its hydroscopic salts coming through the walls, I know different![]()
HyGroscopic :-D
We had a job last year where the client wanted us to dab out to 30mm so I asked BG their opinion and they said don't dab that thickness under any circumstances.
