whats the best plastering tip/advice youve been giving
Lodan
Was thinking today about a few tips pete has given me since I started out and also @zombies bonding in skim tip (which ive now used and was impressed) and was wondering if anyone else had any real good tips they were given that makes life a lot easier....i know its going to sound stupid but the course taught us to lay a ceiling on in waves starting from one wall and then moving back towards the opposite wall...pete showed me to just lay on all the way around the edge and then just fill around the light...only simple but I would have carried on doing it the way I was originally shown and that way is so much faster.
Rossi46
You're supposed to skim a ceiling across the light
adamd
Always cover Virgin boxes and get out of plastering as soon as I can ... all advice from here . :sorprendido3:
john simpson
Look after your body.
Health and Safety is your responsibility.
Don't undersell yourself
adamd
Along with always use a sponge on multi when one coating as the finish is the same as 2 coating ... all priceless info ...
O and I nearly forgot... wear wellies on domestics !!
:eek::p;)
Badgerrrrrrr
Should've been a sparky..................lol
Or should've tried harder at school
Or perhaps I should've gone to school......lol
Lodan
I tried hard at school and did well...did the fancy office job and then did this....you never know maybe this is what you were born to do
roryston
Always go over the top with sheeting up, extra 10 minutes spent sheeting saves extra hours cleaning at the end of the day.
Find somewhere to chuck your dirty water before mixing up
Get your pva mixes right
Spend time on your edges and blends
Dont play with it to much
Fill beads first
Always go with beads no into them or you will get a ski slope
Badgerrrrrrr
Ok, everyday is a school day, work with different people, we all do things different, youll pick up things you like and things you don't, tip for you Lodan, when skimming but a shovel of sand in your water for cleaning your whisk, at the end of a few days poor out, one it helps clean your whisk and two, the skim doesn't stick to the bottom of your bucket.
Olican
Bum Fisting Club
#13
Take the glass out of your halogen lights and the bulbs last so much longer, thanks to @irishspread for that one
Vincey
Clean your skirting boards and windows with a quick sponge over and dry micro cloth after your first flattening.
:hola:
hail hail
Halogen light's! Youd need an oil field to keep them running all the time. Hate the f**k**g things!
zombie
Ref ceiling Pete's way is all fine and dandy if doing small domestic ceilings....
However on bigger works your better typewriter style so that your constantly laying into the wettest plaster and like wise for troweling up.
Can't lay a 40/50/60+ ceiling going around edges first then filling middle...
Also its relative if it takes multiple mixes if its a rolling gauge!
No disrespect Pete BTW bud!
flynnyman
Best tip I got was off render systems and that was scratch my scratch coat on rendering with a float pushing the screws out more :)
Lodan
It was only regular domestic ceilings...anything 40+ I would have another chap with me...did a 25sqm easy enough that way but much bigger and I wouldnt want to tackle it alone for now
Lodan
Also typwriter method was the word I was looking for in my opening post:)
zombie
Good little tip when skimming come in off ceiling/ internals/skirtings slightly on first stroke then go up to on flatten stroke so not to ski ramp or loose detail on cove or skirtings etc
In every room there's always walls areas that will get more critical light ie where day light runs across or walls with uplights/ down lights etc always try and catch them when the lights on them and spent that little more time on them.
Always give walls a good hard dry trowel when walls turning...
Learn how to 1 coat plasterboard trust me it can be done and can earn you a lot of money and save a lot of time and get extra sets in.
Always allow an extra day when saying to customers how long a job will take to give you a bit of breathing space.
Don't book jobs in front specific start date advise a w/c with a view to firming up few days before thus allowing time if hit any problems on jobs before or squeeze in a screamer that you'd otherwise loose.
Only skim dry PVA,
Bead up in between trowels,
Scrim as you go along boarding and stick couple of staples in if going to be a while before skimming.
Always allow for waste materials and round up when pricing...
Price in fuel...
Price in upkeep of tools and maintenance of vans...
Always start early...
Small quick gauged 3/4 easier than 2 big and produce more...
Never rush out of a job without being your own biggest critic...
No your limits...
And the biggest and most important learn how to blend flawlessly then there's never a ceiling or wall that you cant take on...
Stairs pull all top area off baton then pick rest up as a blend instead of up and down ladders...
Only pay yourself a minum wage and bank the rest to cover slow times...
Wear gloves my hands are fooked!!!
Could go on for ever but hey ho...
Builderboi
The plaster gos on the ceiling /wall not on me
CeeVee
Under promise and over deliver (domestics)
Learn how to do a rolling gauge properly.
On ceilings in old houses always work ACROSS the joists. That way no matter how much they run out, your work will always be smooth and LOOK flat. (makes your life soo much easier)
s61
Always have a good come back for some sarcastic b*****d who thinks their telling you something you've never heard before don't just punch them in the face i.e your supposed to get in on the walls not on the floor
Love CBD
roryston
I've seen a old boy doing that his scratch coat was flat as hell
Pug
Always make sure you've got clean boots and hands before you stomp upstairs and rifle through the knickers drawer.
uni-king
Only skim dry PVA,
Price in fuel...
No your limits...
I havnt got patience for 3 gages zombie let alone 4!! I dnt think 1 coating is quicker than 2 aswell u mite save 10 mins if that zombie
