Wire poking out of K-Rend
Geraint
Hi,
I've just had the rendering on our house done with K-Rend. Overall it looks really good but next to the front door there is a wire poking out which doesn't look nice. Previously this was bare brick and the telephone wire ran across the wall. The loop is just before the hole in the wall where it comes into the living room. Our renderer told us that's how they need to be and that the loop must serve some sort of function to do with the phone line but that seems a bit suspect to me. If that was the case, we would have moved the wire before rendering and had it go into the house in a different location but it's a bit late for that now.
There are still some finishing off jobs he needs to do so if possible I'd like to get some other opinions before he's completely done. Do you really need a bit of wire poking out of the render if you have a phone line? As it turns out I think they have damaged the wire anyway as the phone and broadband no longer work but we're waiting for OpenReach to come check it. It would be doubly annoying if we need a new wire so the ugly wire isn't even being used.
What options have we got for the wire?
Thanks,
Ger
That angle isn't over clever anyway, but anything like that I always ask what the customer wants to do, Ie,go around it or remove and refit after.
their job wasn't to re route external wiring so not their fault at all unless you had previously ask for it to be hidden.
