Hi
I’m talking with reference to this job I posted.
https://www.plasterersforum.com/thr...cts-experience-or-similar.73453/#post-1187163
I’d decided on bauwer but lead times for work and long drying times made me look for an alternative option.
i then decided to overboard the walls with savolit wood wool boards stainless stee hammer fixed directly with @pftmonojetman lined up for lime coats in the new year.
My issue is that the wood wool boards are quite soft so getting fixings to work is only effective on the flat, bricked walls. The rubble walls are simply impossible to hammer fix, meaning I need battens and then the whole system is too thick.
So far, ive only done one wall. I’m debating whether to:
A) cut my losses and pull off all the work I’ve done thus far. Suck it up to inexperience of said product and proceed with a bauwer light system application.
B) wood wool board only the bricked/flat walls and combine the bauwer system. This would involve bauwer light on the stone walls, meshed and finished. The wood wool boarded walls would simply be meshed and finished without the light application. My obvious concern with this is two different substrates and differential thermal movement at the corners.
I’m feeling option A at the moment - just sat looking at the job and think option b is asking for trouble but would welcome thoughts.
@pftmonojetman
@vfr12
@Bauwer
Thanks in advance
@pftmonojetman
@vfr12
@Bauwer
Thanks in advance
