Angled block off wood with a screw set where the plaster meets the bead, then run up and down while still green brush in ligtly and trowel out any lines, might have to repeat a few times , turning the screw out slightly for a deeper quirk
Any reason why the chap wants to keep the wooden beads?
I should rip em off and replace with new galv angles/stops or whatever you need to reform your corners/edges
You could freehand your corners but i cant see why you would want too, use a bead, its what they're for
