your opinion matters
Dansouthcoast84
im.after a pre bagged lime render i can spray... pref coloured... and can embedd mesh into...
the client doesnt want to see beading. but cant be arsed to batten 10 million windows out.
last projext i used baumit mp69. scratched it like a mono. then rk79 4mm and sponge..
the rk was a bitch to rub last time so investigating alternatives...
any suggestions
They threatened me when someone said something they did not like on the forum... so instead of passing them stacks of free traffic a highly rank pages on their products they now get naff all
Well done! (y)
Have you finished mono with sponge Dan? Should be more or less the same process. Never used the mp69 .the rk49 what's that ?
they sound like bellends.
think ill pass on that then
i had a sample of sponged finish sent over... clients didnt like it.. too heavey grain..
What sponge do you use ? I use refina which is huge and levels really well after the i bar and then go back again for really fine finish. You can finish it smooth like a glass if you want.
this is the sample i got sent of.sponge
You go over it with the sponge again and will be ok. The second sponge will push back the once with gear around and the once without, like the top of your sample, will be brushed off. I can see why he didn't like it , but it's sample after all and you have to bare this in mind.
With a lot of firms they are happy to take the free traffic but if anything bad or a fact that may not be correct they threaten us....
So hence why I block out certain names..... it's a bit vindictive but still :)
b*ll***s Gypsum is next:ROFLMAO:
Yes. There stuff is brilliant. It's what I most use is there stuff. U won't go worng wit it. The the coverage out of the bags is brilliant to. There ocr does 1.6m2 a bag at 15mm.
can you use it as a thincoat so to speak... as they dont want to see beading i wanted to say spray 10 15mm mesh embedded...
then a skim coat 3mm over too then sponge
