liamruairi
Hi folks, new to this forum so amy advice much appreciated!
Im about to start a lot of work on my house so will be posting here frequently I think!
First job is the kitchen door to outside is being bricked up (new kitchen put in) and I need to plaster the doorway over and the wall its in. House is 1908 non-cavity walls but no damp in kitchen so far. Outside will be old reclaimed brick with breezeblock on the inside. DPC is in place. My question is;
thanks
Liam
- Am I ok to dot and dab straight onto the breezeblock?
- Do I ned to PVA the breezeblock?
- Should I use foil backed plasterboard or is regular board fine given there isnt a damp problem, althouh it is a kitchen?
- I wont be skimming it just joint compound and painting (its a tiny section of wall).
- Are there any building regs regarding plasterboard in kitchens eg fireboard, etc? This is next to the boiler.
thanks
Liam
