alternative to casting plaster for stopping in
stuy
got a small job to fix some cornice , got no casting plaster in van and nowhere here sells the stuff! what else could i use?(only ever done it with casting plaster ) did see another spread a few years ago was using something wasnt casting plaster but left perfect mitres thanks stuy
Multie finish I've done the last two with multie but the last one I put a bit if cement just to speed it up, all painted and looks sweet.
thanks mike whats the set like on the joint filler? when you fix mate what type of gaps do you leave for stopping and wadding etc.. size i mean!! was always taught 10mm?
thanks tony but its only 5 lenth s but will have to put an order in with you soon you got some good gear on your site mate
