Yes you could of used the" zombie mix " or you could of gritted the ceiling after a scrape and them skimmed it.Two coats of plaster over lightly combed artex ceiling, both coats dried quickly and a large area came down about two hours later and also a few small areas where it had not bonded properly.
Any advice please?
I didn't pva. Not white on back of what came off, just grooved as artex. I've taken it all off now and pva'd ceiling, do you think this will be enough with another pva before re-skimming?
I'm looking up pre-grit!
"zombie mix" a mix of bonding and multi finish?Yes you could of used the" zombie mix " or you could of gritted the ceiling after a scrape and them skimmed it.
No p.v.a !!! There's the answer to your question. Unfortunately you have found out the hard way about plastering. Why didn't you just get a local plasterer in to do it. Plastering is not for AMATEURS!I didn't pva. Not white on back of what came off, just grooved as artex. I've taken it all off now and pva'd ceiling, do you think this will be enough with another pva before re-skimming?
Run and bloody fastTwo coats of plaster over lightly combed artex ceiling, both coats dried quickly and a large area came down about two hours later and also a few small areas where it had not bonded properly.
Any advice please?
Hahaha!!! Don't slam the door on the way out!Run and bloody fast
Yes more skim than bonding thoHa ha, had time for a quick fumble between coats!!
For those not reading the thread, I have taken the whole lot down as stated earlier.
Is "Zombie Mix" bonding coat and multi finish mix? please
Hey there's only one Jess the plasterer round these parts!It depends on which plaster you have used for coating. Also, it matters how you applied the coats twice.
If not on boards then walls it should be okIts not on boards
Buy a massive dildo a vibrating one and plug it to the mains and shove it deep up your arse for being an incompetent fuckwit !! Here endeth the lesson
wouldn't blue grit or bond it applied then skim, wouldn't that do it?It's called distemper the white chalky stuff board over it then skim stuff is a fxxking nightmare can't even paint over it
Sounds like the boards mates, Can use Blue grit, leave for 24hrs then PVA and skim as normal. that should do it. Blue grit from Tool station £15 for 5ltrs
Just blue grit and then skim, no Pva neededIf not on boards then walls it should be ok
