Best way to cut aqua panel?
Cornelius
grinder is dusty, saw is slow, Stanley knife isn't quite up to it and constantly changing blades? Going with the knife at the moment...
Just gave the grinder another go, apart from the dust it's the best of my options today I think, have you got a dust bag attached to your saw Dan?
Saw and vac is best. Been looking at spiral saws with vacuum attachments but not many about. Think they would be great though
After a bit of searching i found this, bit cheaper than an m class hoover, its from Hardie boards, had it years,
But m class Hoover will save your lungs (y)
Yeah i know, ive got one, just thinking of a quick alternative to the knife he's using.
I made a gizmo from timber on site ...........basically two lengths of 4x2 with a 12.5mm gap .....fix it to a solid trestle thingy, score the boards with the hardie scoring doodah.....slide between the two timbers.......and snap! ......no dust, no drama, cuts angles and is quite simply a brilliant idea.........( mother is gonna be so proud)....
:numberone:
Best way is to use a circular saw set to very shallow depth, say about 5mm then use the cut as a score and snap the board.
