Bit of hemp
limeplastering
3 coat hemp on wood fibre
Nice job would it be possible use wood fibre boards on the internal but on external walls as they water permeable ?
The is wood wool and wood fibre boards mate they are all a bit different depending where you get them but on a outside you can use them we have before but with a NHL rather then hemp
Yeh I meant the wood wool boards internally instead of coating the solid wall in a 3 coat fashion screw them to and coat as normal on top
