Hi. Im a regular DIYer but a relative novice to plastering. I need to skim 2 areas.. a chimney breast which has Victorian wooden corner beads.. 90 degree ones and the walls around a bay window where the angles into the bay are more than 90.degrees.
What type of bead should i replace the wood with on the non 90 degree angles if I take them out and backfill. I know if i skim over it will likely crack. Or is there a magic alternative?
They are not fancy bull nose beads.
Any advice gratefully received.
