Dri coat
james brown
Hi guys,
Bit of advice if possible please!!
I had a damp problem in a property I rent out. Chopped it all back 2 brick and a leak under the floor was diagnosed as the problem. Had the leak sorted, left to dry for around a month, prob not enough but time is money... I sbr'd the walls then used dri coat.
It's been about 5 days since the dri coat was applied. It's dried everywere apart from 2 small areas were the damp was pretty bad before. Will this dry out or do I have a major problem? Want to do the finish coat but worried about these areas.
Thanks in advance.
Dehumidifier after you hacked off should have been used I do this now on properties that have really bad dampness issues. I leave one running for a week to try and get as much moisture out before I start to re-render
