1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
  1. johniosaif
    johniosaif Private Member
  2. johniosaif
    How do I render this blue foam and block work to have an even and identical finish on both
  3. Dansouthcoast84
    Dansouthcoast84 Private Member
    an ewi basecoat. 6mm. mesh it. pull a tight 1mm coat over it. spat it off
  4. johniosaif
    Over both ? There's a set back of 20mm between the block and foam
    The top gets a capping
  5. vfr12
    vfr12 Private Member
    What render are you using ? Wetherbys styrobond in few coats with mesh will level it out. It's very hard when set and lots of fibre in it. And you will need that, if the blue insulation is what I think it is.
    • Like Like x 2
  6. johniosaif
    I haven't ordered anything yet ,I'd like to do it but I want it right .any help is appreciated
  7. vfr12
    Whatever you are using just make sure is halal mate:D
    • Funny Funny x 2
  8. zolco
    zolco Private Member
    Pmsl
  9. johniosaif
    Halal meat ? Kosher any good
  10. johniosaif
    Don't gang up
    • Funny Funny x 4
  11. CeeVee
    CeeVee Well-Known Member
    Webertherm M1?
  12. johniosaif
    Where is the best place to buy insulation, I've only bought it online before ,which merchants stock it
  13. zolco
    CRT international in romford
    Sig, CCF, probably depends on which system you going with
    Can you not dryfix a 20mm thick slab on top of the existing insulation then you don't have to dub it out with gear.
    • Like Like x 1
  14. johniosaif
    They've passed on the pool for now ,( there's a consultation going on about what was asked for ) I have a first floor bay to insulate with 90mm ,basic job , white finish is all that's asked for , CCF didn't have it in ,said they'd have to order through Weber and I'd need to be registered so I got it online ,Ewistore. This was a previous job ,when I got it online ,haven't ordered or priced this yet @Marshy might advise on Monday
    • Like Like x 1
  15. zolco
    You sorted it then great (y)
  16. johniosaif
    I've edited that ,sorry
    • Like Like x 1
  17. zolco
    P1ss sells Mapei system from the shelves, Johnstone decorating merchant sells their own system you can order it in the shop not stock items but a few on here used them
    • Like Like x 1
  18. johniosaif
    Selco sell some of the Johnstone range ,top coat and base and mesh but little else
    • Like Like x 1
  19. johniosaif
  20. johniosaif
  21. johniosaif
  22. zolco
    Good little job that
  23. johniosaif
    9050mm length ,1425mm height ,two corners ,two windows
    • Like Like x 1
  24. johniosaif
    Very handy for my second job doing Ewi , I might try ewistore , what sort of prices for supply and fitting £1500 or so , about 15msquared
  25. zolco
    I've no idea, last I done was in 2005 in the continent
    I'm sure the usual render guys can give you a ballpark figure
Share This Page
