beader
IF you are putting beads of any kind onto dabs then it needs to have what ever you are using
(finish , bonding ,s and c etc)both behind and on top of the flange or web, just on top is inadequate and will not stop movement resulting in cracking or the bead coming loose if knocked . staples are no good imo so i always fix with pb nails when possible and run some scrim over the web on thin coat beads.
