1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
Forced-action pan-mixer: any advantage of 2.0kW over 1.1kW motor-power
Discussion in 'General Machine Discussions' started by Michaelangela, Nov 8, 2017.
  1. Michaelangela
    Michaelangela New Member
    I need a forced-action pan mixer for an old cottage renovation - mortaring and rendering all walls and putting in lime and glypor floor. The options seem to be between a 1.1kW motor and a 2.0kW. The aggregate will be a sharp builders sand. Is there any advantage to the 2.0 kW or would that be overpowered? Any advice would be appreciated.
  2. zolco
    zolco Private Member
    Best if you give a ring ces hire in high Wycombe, they have forced action mixers for resin they might be able to help
  3. vfr12
    vfr12 Private Member
    What lime are you using and how big is the project? You might consider the roller pan mixer and the stronger the better in my book
    • Agree Agree x 1
  4. Michaelangela
    58 Metre square (outside dimensions) with 1 M thick double stone walls, hearted with rubble. So far (joint repair and dubbing out) I have used a conventional Belle/Honda mini-mixer. Now at the rendering stage the mixes take too long and not sufficiently consistent and reliable. Is it OK to mention brands here? The choice is between SoRoTo 1.1 Kw 80L pan-mixer and a Baron which has a 2.0 Kw of the same mixing-capacity.
  5. vfr12
    Both will do the job then. 80l might be too small I’ll go for 120 . personally will
    Go with baron and will get the easy clean set.
  6. PFTwales
    PFTwales Private Member
    Could you hire one for this project, by hiring you have the flexability of upgrading or downgrading. You can also decide if its worth investing in one, they are large bits of kit to carry round . CES hire will likely have the suitable model
    • Useful Useful x 1
  7. Michaelangela
    Thanks for the tip Zolco but I want to buy not hire.
  8. zolco
    They sell machines too
  9. Michaelangela
    That's helpful. The 80L Baron has the advantage of passing through the internal cottage doors which are smaller than modern standard, and the adjustable telescopic legs will be useful on a mountainside site, where the floor-level slopes steeply.
    Thanks to all for the advice. Off to negotiate!
  10. Michaelangela
    Will contact them tomorrow Zolco. Thank you.
    • Like Like x 1
  11. rlcleary1
    rlcleary1 New Member
    Good advice there zolco
  12. zolco
    You still on timber frame houses Bobby?
  13. rlcleary1
    Yes mate it’s taken off in a big way down this way.
    The majority of work we are carrying out is the Sas prowall cladding system
    There’s a bit too it but it’s a good system through out
    Bit of a pain trying to get the silicone finished in the colder months but we get there in the end!!
    • Like Like x 1
Share This Page
