Hard wall to build up over paint
Archie1971
Hi all I hope someone can advise me if it's ok to use hard wall straight over painted walls without Pva ing the walls, need to build up around 7 mm above picture rails as the previous plasterer skimmed the underside to a poor quality.
thanks Archie
when i"ve done this in the past i have also got a Stanley knife and run the knife criss cross all over the areas to be bonded just to get some key on the wall
When you leave it rough, you then rough it up more with your knife
thanks Archie
Are you off your head ?
