Hardwall soft and dusty after 3 days
Robb1e
Hi I'm new to plastering, been a decorator for 30 years.
I hired a plaster to do my home, he did my ceilings due to limited time.
I had 2 smallish walls and left to do in 2 rooms where plaster coat had fell off the walls and left old bonding.
He recommend I apply a coat of hardwall and fill out plaster over the top.
The original bonding was a dry powdery surface.
I applied pva to the surface and left for several days, then applied a coat of hardwall.
I mixed it like plaster applied with a trail and could not play with it to much after as it started to pull but got a level surface.
After 3 days now it is soft.
If I run my hand over the surface dust comes off and if I run my finger tip over it I can leave a mark, I've never used hardwall is it not meant to go hard?
Spoke to plasterer and he recommended i apply PVA and fill?
Many thanks for any future replys
Rob
  • VID_20180830_082414.mp4
You hired a plasterer so why the f**k are you trying to hardwall a wall?
Basically you wanted it as cheap as possible so offered to do all the prep, and f**k*d it up lol.
It’s a basic job tbh, as above might be simple solution to just have plasterer plaster it as something isn’t right
No I asked him to do it but he didn't have any hardwall on his van and not the time as he did it in the evenings after work.
He did 5 ceilings and for how much he was going to charge for walls was next to nothing.
I needed to get the job done and it was what he suggested.
I reckon you’ve not pva’d the wall enough to kill the suction and it’s pulled the hard wall in too fast
Thanks for reply
It did have a decent coat of pva
I picked up a blob of hardwall that fell on the floor when I did the wall and it is rock hard.
On the wall it was only 2-5mm, did I apply it thick enough to the wall?
think tiny tom spot on pal I was going to say look at bags for out of date stuff; but if bit on floor set ok then to much background suction the answer strip back to brickwork and get plasterer back
Thanks for reply
if you read the instructions on the side of a bag of hardwall it states do NOT apply to pva.
