Hi am leight
Leight
Hi could someone please give me some advice
I had a leak coming from roof and all the paint on the interior wall was bubbling so I scrape the paint off but some of the plaster was coming away from the wall so I’ve took all the loose plaster off.After getting ripped off with the first roofer I’ve had to get another one in to sort the leak out.
i was going to try and skimm the wall myself do I use bonding 60 first then a easifill or can I just use a all in one plaster.I can afford to pay a plasterer so I need to give it ago,I would truly appreciate some advice please
ive had my leak sorted out,now just waiting for the wall to dry out am also using a dehumidifier to help dry the wall out.
Am only asking for advice,if u can’t say anything helpful don’t comment on my post please
yeah we all in the same boat bills to pay
Aww thanks least someone understands I can’t afford it
Ffs here. We wuz just joshing.
You're going up to skimcoat with skimcoat, right?
So yours will be the same depth, roger so far? If you fill the hole then the few mm of your skim will sit proud, capiche?
So, pva your hole and the surrounding area, bung on some skimcoat and flatten and blend it in.
Oh you dont know how to blend it in and you cant afford a plasterer?
Then you should ring @Chrispy He can't blend either but he's cheap
