Exothermic reaction i think .:RpS_unsure:Cement is a bit iffy as it can cause the plaster to sheet. Dirty water is best IMO. The chemical reaction between the water and plaster is simply speeded up, because you are adding something where the process is underway, it acts as a catalyst.
Gas gets turned into a liquid = heat, which is expelled by the radiator ducting on the back --- liquid then evaporates back into a gas which draws heat from within the fridge. (Use a bike pump and it gets hot - use a calor has bottle and ice forms on it. Simples )How do explain a fridge then ?
