Here are some images showing one of our recent exterior marmorino applications in Chester.
Marmorino exterior
The developer had originaly intended to use a High build textured finish.
Therefore the base was not exactly left smooth!
The sand/cement render was sealed with a siloxane/lime solution before carefully applying 2-3 layers of pure white marmorino and lightly burnishing.
The result is stunning and the property glows bright white in the sun due to the marble/lime finish.
90% of the application was carried out alone, without scaffolding (just off ladders) and we had to wear sunglasses during application.
Marmorino exterior
