I’m doing up a house as a rental project & it needs to be skimmed right through. We’ve overboarded the ceilings as they had various holes from lift fittings being moved, studded & boarded the bathroom to get some insulation in, and stripped the paper off the walls.
The plasterer said to paint the walls with ‘either Green Grit or Plas Prime’.
Just wanted to ask the audience thoughts on these two products as both seem to be twice the price of the stuff most commonly discussed on previous posts…the blue grit type stuff…if it was your money, which would you go for?
Also, do I need to coat the new plasterboarding on the ceilings or bathroom with anything, or do you just skim straight on to it?
