Overcills
Jgreenplastering
Anyone recommend a decent place to get overcills.
Clients had new windows installed with the largest possible cills but once our EWI and render goes on it's still going to leave only a inch or so of overhang which I detest so need a decent proper overcill.
Cheers
When I fit EWI I usually cut a piece of eps down to size so it's the same size and the same over hang as the cill was originally.
I stick and pin it to the face of the cill then mesh and bead it
I've just started using meshed window beads from amaroc they work really well and gives the perfect drip so the walls don't stain.
Am not sure if you will see the cills properly on the picture
if job is having new windows weve never had problems getting a big enough cill.
always ask for 140mm overhang from face of existing wall.
or they should of pulled windows out further when fitting
And sounds a f**k**g shambles
Most of the EWI jobs I do all have original casted sills so the customers still want to retain that look.
These sills have been extended with eps and meshed and beaded
Does anyone use the insulated oversills with the built in drip
