No you don't your loft needs to be seperate to the rest of your house with a fire door. You could never have a corridor from a loft to your front door it wouldn't be worth doing and would be impossible in most If not every style house. If you have a fire in the loft you need to be able to shut it off with a door and escape out the house and the same if there is a fire in the house shut it off and escape out the loft.Thats why you need to have direct acess to your front getting out on the roof is not considered anymore you basically have to have a corridor running to your front door
I'm sure if the house was on fire you wouldn't be saying that lol this is one of the biggest sticklers when converting a loft, an escape route and I'm pretty sure they wouldn't drop it to make things easier and unsafer but I stopped converting lofts about six years ago so maybe they have changed but I doubt it.You need direct acess from the loft to the front door without entering any habitable rooms the roof is not considered a safe place to escape to anymore
So going off this your saying you could convert your loft without any windows and this would be fine?You need direct acess from the loft to the front door without entering any habitable rooms the roof is not considered a safe place to escape to anymore
What your saying is correct about habitable rooms but you also need what I said if what your saying was fact there would be a lot of people killed every year and the. It would be changed back. Who gave you the info?Yeah it did change as i was going to do mine this is what i was told i would have had to turn my stairs around
They told you you don't need an escape route from the loft?My local council building regs
If there was a fire down stairs how could you escape?The escape route is down the stairs out the front door
And every door is locked and you are awake once the fire starts lol if the whole of downstairs is on fire you ain't getting out if it starts in the early hours and your asleep in your new loft conversionBecause you aint going through any rooms
Lol I won't have to you might burn to death if you go ahead with your loft conversionThats what i was told dont shoot the messenger
Self closers have gone a few yrs now, I did a loft a few years ago 2010 and I didn't need fire doors as linked smoke and heat alarms sufficed,did one in 2013 and needed them,they all interpret the rules differentlyYou need linked smoke alarms, insulation, fire doors throughout (depending on your council) self closers on every door, a seperate consumer unit is a benefit, heating and so on. A dormer is more expensive but this can usually give you your head height for your stairs, an extra room or even a bathroom and the views can be superb.
We used private b I the last time and found them easier to work with but they are strict with the rules, they make a maximum of three visits and then photos sent after that, found it easier than dancing with the council, everything is done online, PDF sent over and back all signed off..Yeh each job is different and so is each BI get on the wrong side of them and they can make it very difficult.
Is he the only draftsman in the village xxxxxYep the chap is a draftsman I think does all the drawings in the village
Also the postman and pizza delivery guyIs he the only draftsman in the village xxxxx
