plazzy float
ahh well at lest its only a couple of quid youve lost out if you want a cheap one to try and see if you like it try the barton one im always on about, i only bought it cos i was sceptical about the whole plazzy thing but i tried it and loved it, it still looks cheap but ive had mine coming on 2 years now and its dream every time i use it
never used 1 before so will have see how i go think edges might need sanding down though spunky whats best way??
bit of wet and dry on the edges and corners then just use it do set in the morning and when its browned up run the trowel over it to take any thing off or run it over some plaster board, i used the wet and dry to smooth it off but the cheapy one i used and get on with it this one Bartrowels
plazzy float
Dave50 still uses little builders buckets he's never seen a spot board before, mine hasn't turned up yet tbh they look like a float when mine turns up Ive got a vice in the garage Ill put me leccy sander in and wear the edges down
The edges are ok Dave. I used mine today on the final flatten of hemp putty and it worked a treat. Closed it in real nice.
Did some skimming on another job this afternoon but forgot to use it. I'll try tomorrow on finish.
It's very rigid with curvature fron nose to tail that would only be nullified with pressure on a final trowel.
Bent the wrong way?......I left my barton trowel on my windscreen today and I thought it melted lol
Ha Ha your full of spunk ya 1 coat plastic sponger:RpS_lol:
Danny what's wrong with your plazziflex?
If you mean the refina one, then nothing.
It actually has loads of uses, lately i have been using it to flatten fine hemp finish on the same day as applying. This makes it so much easier to get the final finish on day 2 or 3.
The refina is sh1t loads more flexable than this ebay thang, so has a completely different forte.
It's like comparing youporn to extremetube.........both great but very different at the same time. :RpS_thumbsup:
