Protect Your Render With Render Reinforcement Mesh
New GoMesh will provide your exterior render with strength and crack resistance for a fantastic finish for years to come. Introductory discount now available!
https://www.plasterersnews.com/protect-your-render-with-render-reinforcement-mesh/
I've been using k-rend mesh in cement renders for years seems like the same idea also use k rend mesh inside if bonding over areas with a lot of wide cracks etc
What a load of b*ll***s @Danny, if you use any mesh other than that of the manufacturer of the render you're applying you must be nuts. Parex render, Parex mesh, Weber render, Weber mesh, simple.
What a load of b*ll***s @Danny, if you use any mesh other than that of the manufacturer of the render you're applying you must be nuts. Pared render, Parex mesh, Weber render, Weber mesh, simple.
How many times has any of your mesh failed?
