Hi
Need some advice regarding rendering my own house. We run a building company but get involved with little rendering.
The house is half heather bricks and half new concrete blocks. There is about 125 m2 to render. I have considered self coloured render but all the jobs around here look stained and dirty at 5 yr mark. I think a system which is paintable is best.
I am looking for a 15mm finish, very smooth and paintable. I have to get this right as the window reveals get rendered before the windows are fitted, so to do again would be a nightmare after windows are in.
I have a team of highly skilled plasterers who have some render experience but are looking to me for the spec. I got them to do a couple of test panels on a garage wall due for demolition and it looked good
4 to 1 scratch with feb
5 /1 /1 top coat with lime
All plastering sand and ordinary Portland cement ( no additives)
Sponged finished on one panel, sponged finish and then metal troweled twice on another.
They complained the top coat with lime was un workable until a water proofer 3 in 1 was added ?? thought hydrated lime was a plasterciser.
Finish wise the standard sponge was a bit sandy, would look like sandtex if painted with smooth masonary. Although a light brush when hard may solve this .The trowelled finished looked better but it had slight lows where it obviously doesn't work like multi finish. Unsure if this is achievable over 125m2 rather than 1 m2
My questions are
I want it smooth and sharp, is sponge best
Should we use a slurry coat due to bricks and concrete
Should I mesh the vertical joint of the bricks and concrete blocks, and mesh anywhere else?
Should we use stronger or weaker mixes
Should we use waterproofer in the scratch coat to prevent suction. Will the retarder be wanted at this time of year ( poss single digit tempertures)
Should we use waterproofer in the top coat, or lime or are both compatiable
Do I need frost proofer for safety, one 15m x 5m wall is north facing and doesn't get much light or even an accelerator ?
Is S/C old hat and should I be using a more modern product that can be trowel finished and painted ?
My concerns are the correct mix and the fact the render is going on at this time of year. I would be painting with keim mineral paints
Any advice welcome
Matt
My questions are
Any advice welcome
Matt
