Nice one mate lol was thinking about you yesterday set mine up for my moment of glory all the gear was ran through for material test and was good to go, machine was on grass near the mud ready for quick wash out ( bearing in mind what you said about mess the other day) all I had to do was connect the material hose and air and away she goes... Only problem was I couldn't connect the frigging air to the b*****d gun, to cut a story short still didn't connect it after 45 bob stain minutes cleared all the crap out the hopper sod knows why I took rotar stator off in anger to wash hopper out and then forgot to wash r/s which then had set plaster in it, what a day,lolJust finished a k1 spray job with my ritmo and it was over 100m2 which took me three days . Happy with the machine once its going as its a dream . Did have a few set up issue but that's as to be expected as I'm new to this machine stuff .
I had to clean mine out twice this week and did the same thing take out the all apart but when I got home I took the r/s off and it had a hard bit of gear at the bottom on the shaft which explain why it wasn't pumping correctly on Thursday . This time next year we will be like @theclemo and we can do it in our sleep .. Did u spray yesterday .? Have you got someone with you on it ?Nice one mate lol was thinking about you yesterday set mine up for my moment of glory all the gear was ran through for material test and was good to go, machine was on grass near the mud ready for quick wash out ( bearing in mind what you said about mess the other day) all I had to do was connect the material hose and air and away she goes... Only problem was I couldn't connect the frigging air to the b*****d gun, to cut a story short still didn't connect it after 45 bob stain minutes cleared all the crap out the hopper sod knows why I took rotar stator off in anger to wash hopper out and then forgot to wash r/s which then had set plaster in it, what a day,lol
Funny thing is thought this ain't getting me down had some advice off @theclemo (top man ) cleared out r/s ( I think) and then youtubed the blumming air connection on power coat ,lol ... All I had to do was push it on but I kept pulling fitting part back ... Another lesson learnt
Didn't spray, going to set ,spray and clean down a few times this weekend at my house should of done it last weekend really to familiarize myself,got to get this sorted ,work on my own but when use machine I had my mate with meI had to clean mine out twice this week and did the same thing take out the all apart but when I got home I took the r/s off and it had a hard bit of gear at the bottom on the shaft which explain why it wasn't pumping correctly on Thursday . This time next year we will be like @theclemo and we can do it in our sleep .. Did u spray yesterday .? Have you got someone with you on it ?
TI had to clean mine out twice this week and did the same thing take out the all apart but when I got home I took the r/s off and it had a hard bit of gear at the bottom on the shaft which explain why it wasn't pumping correctly on Thursday . This time next year we will be like @theclemo and we can do it in our sleep .. Did u spray yesterday .? Have you got someone with you on it ?
Looks good
Looking back now it's Saturday I am glad I messed up on Thursday,onwards and upwards for the newbies crew,lolT
The only reason am getting on a bit quicker with the ritmo is because I've used diesel machines and had a small pump like the eze machine b4. There will be days of me ringing pft. Am sure of that. It all takes me back to my first machine that I bought from strata but I had no back up form them c**t's. I had to figure it all out the hard way. So now if I have a problem with the ritmo I 95% of the time I'll sort it out myself in less than 2 min. And to be fair it's all ways user error. So when it goes worng just think what did I do worng and take your time to find the problem.
must have been very tight and awkward with the scaff on the gable mate
Ive seen more parts of your machine then my own lolSpent today getting absolutely everything cleaned out good job I have as well found a little clump in the top water in let which would of stuffed me up.
Might be a newbie but I getting there,lol
I'm a bit surprised that you own a bench vice [emoji12]
I took mine apart yesterday and there was crap in loads of places so I'm going to take it apart after every job just to keep on top of it .Spent today getting absolutely everything cleaned out good job I have as well found a little clump in the top water in let which would of stuffed me up.
Two towers and a 6m2 young man wasn't the best to work off but we did it .must have been very tight and awkward with the scaff on the gable mate
Not mineI'm a bit surprised that you own a bench vice [emoji12]
Thanks will do .. Could not get the green skim set stator one out .. Tried the other just to check it was okjust buy a rotor screw for taking out rotors much easier
2 bar would be enough though,wouldn't it?I'd wait until you have the water butt and pump. Less things to go wrong.
Go for it !Ritmo advice please,got about 20m2 tomorrow on gable with ocr, haven't got pump and barrel yet and know everyone will say to use them (which I will when it comes) but for this job tomorrow would I get away with 2 bar plus off the tap, it's a church and nobody will be using water and the pressure is very good off the tap.?
I did a job on a church with hardwall I had 2bar it was OK but the mix did change but got there in the end. U can have a lone of my barrel and pump if you want it lol2 bar would be enough though,wouldn't it?
I can't wait anymore,lol it's getting ridiculous
Clog the machine. Lose a days work. Waste render lol. I'd say u might be ok tho it's only 23 bagsSod it ,i do it thanks Keith uk and Ireland what's worsed that can happen?
CoolClog the machine. Lose a days work. Waste render lol. I'd say u might be ok tho it's only 23 bags
could do more harm then goodI took mine apart yesterday and there was crap in loads of places so I'm going to take it apart after every job just to keep on top of it .
Ran Hardwall through it off tap at around 2 bar after a few bags it started pumping out like piss wasn't sure if it was the water pressure dropping but ended up getting a few more done then handball a few cleaned up and was ok,tbh if it goes s**t up tomorrow can always do same it ain't massive area.Tbh if the water pressure is ok why not ,we ran of the mains for years ,but thats with a g4
always spray wetter then you would handball ,most in the early days of having a machine try and get the mix to dryRan Hardwall through it off tap at around 2 bar after a few bags it started pumping out like piss wasn't sure if it was the water pressure dropping but ended up getting a few more done then handball a few cleaned up and was ok,tbh if it goes s**t up tomorrow can always do same it ain't massive area.
@MikeAtthis ,@UKPlasteringmachines ,@theblonesThanks Keith, @theclemo says around 300 then lower if needed I blame him if goes wrong
