Rough casting with machine
Ivor
Hi lads, what's everyone's method when it comes to rough casting / Tyroleaning with machine? Spray rule and spat flat then let it pick up and texture same day ? or Ibar flat when ready and texture same day or next depending on weather ect ? Cheers
Spray, rule flat, go over with a spatula to get it as flat as you can and get rid of any heavy lines etc, leave it a hour or so then slower speed and texture away
So slower r+s ant thing with float ? And what spray cap would you use ? Thanks
yes id use a d3-4 or 5-3 for slow output and a green lightweight float will show more of a water reading . use the same thickness material for both applications
