I boarded an oddly laid out stud wall, having finished this I noticed in some parts where the boards join, there is a bit of play when pressed as there is no joist behind that part.. it's only slight
Will skimming the wall strengthen it or should I take the boards off and add a joist in there? i worry that once skimmed if you leant on that part it might crack..
Thanks in advance
Thanks in advance
